Create a Project
Your guide to creating, editing and completing a floor plan!
Create a Floor Plan
- How to Create Your First Floor Plan
- Creating Rooms in magicplan: Choosing The Right Method
- How to Duplicate a Project in magicplan
- Create a Project in the magicplan Cloud
- Connect a Compatible Bluetooth Measuring Device with PrecisionLink
- Add a New Floor & Room
- Scan a Room With the Camera of Your Mobile Device (iOS)
- Scan a Floor Plan with LiDAR Auto-Scan (iOS)
- Scan a Floor Plan with Manual-Scan (iOS)
- Create a Room With the Square Room Feature
- Create a Room With the Draw Room Feature
- How to Use Filler Rooms or Walls
- Import and Digitalize an Existing Floor Plan
- Create a Land Survey
Assemble & Edit a Floor Plan
- Floor Plan Editor FAQ
- How to Change a Room Name
- How to Create Angled Walls
- How to Delete Walls
- How to Rotate Your Floor Plan
- Assemble Your Rooms to Create a Floor Plan
- Change the Wall Dimensions of Your Floor Plan
- Undo & Redo
- Change Exterior and Interior Wall Thickness
- Set Ceiling Height of a Floor or Room
- How to Add Corners to Walls
- How to Add Partial Walls to a Room
- How to Duplicate Rooms
- Split Rooms
- Merge Rooms
- Delete Rooms and Objects
- Copy a Floor to a Different Project
- Move a Room to a Different Floor
- Change Room Color
- magicplan Diagonal Measurements
- Add Details to Your Project, Floors, Rooms, and Objects
- How to Capture an Affected Area in magicplan
Add Objects & Custom Objects
- The magicplan Object Library
- Add Objects to Your Floor Plan
- Create Objects with the Object Manager
- Edit, Duplicate, & Mirror Objects in Your Floor Plan
- Measure the Distance Between Objects and Walls / Other Objects
- How to Edit Wall Objects in Elevation View
- Create Your Own 2D Objects by Importing SVG Files
- Import Custom 3D Objects in magicplan
