- Help Center
- How can I measure and sketch?
- Create a room
What's new with magicplan
FAQs
Pricing and Billing
Privacy & Terms
Integrations and API
Update Log
Workspaces
Create a Room With the Square Room Feature
Learn how to create a floor plan of a square room by drawing.
- Go to the Home Screen.
- Open the project you want to edit.
- Tap on the '+' icon to add a new room in project view, or select the 'Add' button in floor view
- Tap on “Add a square room“ and select floor and room type you want to capture.
- A square room appears and is ready for your adjustment. Change the dimensions by tapping a wall and moving it with your finger or by entering a different value.
Note: You can also edit the room shape by moving the corners or even by adding additional corners to your room.
