Set Ceiling Height of a Floor or Room
Improve the accuracy of your floor plan by setting the ceiling height of an entire floor and individual rooms.
Set the Ceiling Height of a Floor:
  1. Open a floor of your project.
  2. Tap the "i" icon next to the floor name (i.e. 1st Floor).
  3. Change the ceiling height under Measures. This can be done manually or by connecting to a Bluetooth Laser Measurer.
  4. The ceiling height will be applied to every room on the floor.
ℹ️ Note: If you change the ceiling height of a specific room prior to changing the ceiling height of the entire floor, the floor ceiling height will not be applied to that room.
Set the Ceiling Height of a Room:
In the case that not all rooms have the same ceiling height, magicplan gives you the option to set the height for each room individually. Follow these steps:
  1. Tap the room you want to set the ceiling height for (grid lines will appear in the room).
  2. Tap the "i" icon next to the room name.
ℹ️ Note:
  • The ceiling height of individual rooms does not display in the 3D view of your floor plan. The displayed height is by default the highest room on the particular floor.
  • Ceiling height will show in your PDF exports when the ceiling height of rooms has been changed from magicplan's standard 8 feet or 2.44 meters.
  • Ceiling height displays as "wall height" in your project statistics.
💡Tip: It is not possible to have a sloped or vaulted ceiling with the current version of magicplan. However, you can find options to indicate sloped or vaulted ceilings here.
