- Help Center
- How can I measure and sketch?
- Adjust your floor plan
What's new with magicplan
FAQs
Pricing and Billing
Privacy & Terms
Integrations and API
Update Log
Add Partial Walls
Add partial walls with ease.
You can add partial walls to any room. Select a wall and tap on the spot where you want to add the wall by tapping on “Add Wall” at the bottom of the screen. Then tap on “Partial Wall” and adjust the added wall by dragging it into the correct position or by changing the dimensions.
Partial walls will not connect to each other – instead, you may choose to split your room.
Need further adjustments or to add a walk-in closet to your room? Why not try adding corners and fill in the empty space with a filler room? It works like magic.
