Change Exterior and Interior Wall Thickness
Change the exterior and interior wall thickness to make your plan more precise.
Not all walls are the same. Therefore, you can change the exterior and interior wall thickness of your plans. Just follow the steps below:
  1. Open a project and enter the Floor Level.
  2. Tap on the “i" next to the floor name, which will open the details menu.
  3. Here you can change the interior or exterior wall thickness manually – or measure with a laser.
ℹ️ Note: At the moment it is not possible to change the thickness of individual walls, you can only set an interior and an exterior wall thickness for each floor. Please keep an eye on our webpage and product update reports for news on this feature.
