How to Rotate Your Floor Plan
Easily rotate the entire floor for better alignment or presentation.
Rotating your floor plan in magicplan helps you present your layout in a way that makes the most sense for your project. Whether you're prepping for export, aligning your floor plan with a real-world reference, or just want a clearer view, here’s how to do it.
- Open your project and navigate to the floor level you want to adjust.
- On the left side of the screen, tap the “Rotate” button.
- A green arrow indicator will appear in the center of the screen. Drag this arrow to rotate the entire floor to your desired orientation.
- Once you're happy with the positioning, tap anywhere outside the arrow indicator to confirm and set the new floor plan orientation.
ℹ️ Note: If you’ve added furniture, walls, or labels, rotating the floor won’t affect their placement—it simply changes the viewing direction of the entire floor layout.
