Create a Room With the Draw Room Feature
Manually create a room by free-form drawing the walls in the app.
Whether you are mapping out a new room or an unusual room shape, “Draw Room” gives you the flexibility to draw the room corner-by-corner.
How to create a room with the "Draw Room" feature
  1. Open the magicplan app.
  2. Open the project you want to edit or create a new project.
  3. Tap on the floor you want to add a room to or add a new floor.
  4. Once on the floor level, tap "+ Insert", then select "Room".
  5. Tap "Draw Room" and select the room type you want to sketch.
  6. Draw the room by tapping the corner locations. Use the grid in the background to estimate the length and angle of your walls.
  7. After you add all the corners, you can then adjust the dimensions of your room to ensure all measurements are correct.
ℹ️ Note:
  • If your units are set to "Metric", one tile equals 1 square meter.
  • If your units are set to "Imperial", one tile equals 9 square feet.
  • Learn how to change the units of your projects here.
