- Help Center
- How can I measure and sketch?
- Create a room
What's new with magicplan
FAQs
Pricing and Billing
Privacy & Terms
Integrations and API
Update Log
Workspaces
Fill Rooms
You have created the majority of rooms for your floor plan. But there are some spaces that still need to be filled? Fill them with one tap.
If you have created a complex floor plan with many rooms, it occasionally happens that a space remains between rooms. In order to fill the open space tap on “Add Room” or “New Room” and select “Insert a Filler” afterwards. Choose between “Filler Room” and “Filler Wall”. Select the space that should be filled. The void will be automatically filled with a room or wall.
