title: The magicplan Menu Structure
description: Use this guide to find your way in the magicplan app.
[Skip to content](https://help.magicplan.app/the-magicplan-menu-structure#main-content)
- [English](https://help.magicplan.app/the-magicplan-menu-structure)
- [Deutsch](https://help.magicplan.app/de/die-magicplan-menüstruktur)
- [Español](https://help.magicplan.app/es/la-estructura-del-menú-de-magicplan)
Show submenu for translations
Open main navigation
Close main navigation
- - [English](https://help.magicplan.app/the-magicplan-menu-structure)
 Hello, how can we help you?
2. [Getting Started with magicplan](https://help.magicplan.app/getting-started-with-magicplan)
3. [Intro to magicplan](https://help.magicplan.app/getting-started-with-magicplan#intro-to-magicplan)
# The magicplan Menu Structure
## Use this guide to find your way in the magicplan app.
magicplan has different project levels and contextual menus. Here is a brief explanation of the menu structure to help you to find your way in the app!
### **Home Screen**
The Home Screen is the first screen you see when logging in and opening the magicplan app where you create and manage your projects.
- Search for projects in the Search bar.
- Manage your projects by tapping and holding on the specific project (or tap the "..." ellipses symbol); a pop-up menu will appear allowing you to:
    - Favorite your project to make it available offline
    - Duplicate or [move your project](https://help.magicplan.app/move-projects-within-your-workspaces) to a different workspace
    - Archive projects you no longer access regularly
- Access your Favorites or Archived projects using the category buttons in the upper left corner beneath your Workspace title.
- Create a new project by tapping the plus sign (+) in the "New Project" box.
- Use the workspace menu found in the upper left corner to switch between your Workspace or Team.
- Tap the profile icon labeled "Profile" on the bottom navigation bar to access your app and account settings.
### **Project Dashboard**
Tap a project from the Home Screen to get to the project dashboard.
- Find an overview of your project's floor levels and details.
- Add a project description, including the name, description, author, project creation date, and parameters for the living area calculation. If you've created [fields](https://help.magicplan.app/create-custom-attributes) in the Cloud, you can apply them to your project here.
- View basic statistics for your project; scroll to the left and tap "See All..." for a full list of all project statistics.
- Duplicate or delete floors you've created by tapping the three dots (...) icon or tapping and holding the floor level.
- Add [new floors & rooms](https://help.magicplan.app/add-a-new-floor-ios) to your project.
- See and [edit details](https://help.magicplan.app/add-general-information-and-photos-on-floor-plan-level), favorite, add photos & notes, and complete [forms](https://help.magicplan.app/custom-forms) for your project.
- View all of your magicplan exports for the project in the Files section. You can also upload associated files like receipts, invoices, and contracts for unified project management.
- [Create an estimate](https://help.magicplan.app/estimate-materials-and-costs) for your project (only available on tablets with a stable wifi connection), or [export and share](https://help.magicplan.app/files-and-sharing-version-9.5.0-update) your project.
### **Floor Level**
Tap a floor from the project dashboard to get to the floor level.
- Find and add [details](https://help.magicplan.app/details-photos-notes-and-forms-update-version-9.5.0) for a specific floor.
- [Add](https://help.magicplan.app/add-a-new-floor-ios), [duplicate,](https://help.magicplan.app/duplicate-rooms) [delete](https://help.magicplan.app/delete-rooms-and-objects), or [merge](https://help.magicplan.app/merge-rooms) rooms.
- [Assemble rooms](https://help.magicplan.app/assemble-your-rooms-to-a-floor-plan) into a floor plan, view the floor in [3D](https://help.magicplan.app/create-and-view-3d-models-in-the-magicplan-app), and even rotate the floor.
- Change the interior and exterior [wall thickness](https://help.magicplan.app/change-exterior-and-interior-wall-thickness) for the entire floor, and set the floor's default [ceiling height](https://help.magicplan.app/setting-the-ceiling-height-for-a-specific-floor).
- Switch between floors by tapping "Floors" in the bottom right.
### **Room Level**
Tap a room from the floor level to get to the room level.
- Add objects and annotations.
- Add photos & notes and complete [forms](https://help.magicplan.app/custom-forms) relevant to the room.
- See and edit [room details](https://help.magicplan.app/add-information-and-photos-on-room-level) and adjust [ceiling height](https://help.magicplan.app/adjust-the-ceiling-height-of-single-rooms), [room color](https://help.magicplan.app/change-room-color), and room type.
- View walls in [elevation view](https://help.magicplan.app/elevation-of-windows-doors-and-other-furniture-objects-attached-or-next-to-a-wall).
- Tap a wall to [add corners](https://help.magicplan.app/add-corners), [split rooms](https://help.magicplan.app/split-rooms) or add a [partial wall](https://help.magicplan.app/add-partial-walls).
### **Object Level**
Tap an object in the room to get to the object level.
- See and edit object details, such as measurements, photos & notes.
- [Duplicate](https://help.magicplan.app/duplicate-furniture-objects) or [delete](https://help.magicplan.app/delete-rooms-and-objects) the object.
- [Measure the distance](https://help.magicplan.app/measure-the-distance-between-objects-and-walls/other-objects) between the selected object and another object or wall.
- It is important to note that you can also see and edit details about your walls by tapping a wall in the room!
ℹ️ **Note:** Don't forget that practically ***everything*** in magicplan has a details section, identified by the "i" symbol, for you to add valuable information.
💡 **Tip:** The more detail you add to your project, the better your [exports](https://help.magicplan.app/export-your-projects) will be!
