title: How to Export Your Projects in the App and Cloud
description: Learn how to export your projects in 2D and 3D effortlessly.
[Skip to content](https://help.magicplan.app/export-your-projects#main-content)
- [English](https://help.magicplan.app/export-your-projects)
- [Deutsch](https://help.magicplan.app/de/exportiere-deine-projekte)
- [Español](https://help.magicplan.app/es/exporta-tus-proyectos)
- [Français](https://help.magicplan.app/fr/comment-exporter-vos-projets-dans-lapplication-et-le-cloud)
Show submenu for translations
Open main navigation
Close main navigation
- - [English](https://help.magicplan.app/export-your-projects)
 Hello, how can we help you?
2. [Export & Share Projects](https://help.magicplan.app/export-share-projects)
3. [Export Your Projects](https://help.magicplan.app/export-share-projects#export-your-projects)
# How to Export Your Projects in the App and Cloud
## Learn how to export your projects in 2D and 3D effortlessly.
You can easily export your projects in various formats, allowing for seamless integration with different software and satisfying the needs of your stakeholders. Whether you are a restorer, renovator, contractor, or designer, magicplan streamlines the process of sharing plans, eliminating communication gaps and saving valuable time.
ℹ️ **Note:** By default, newly created exports overwrite the previously generated file of the same type. You can update your workspace settings to retain the original file and create a new one (e.g., Sketch, Sketch 2, Sketch 3)
- In the magicplan Cloud, go to Settings \> Export \> Export File Versioning and check the box to create new versions instead of overwriting the previous file.
### **How to Generate Export Files in the magicplan App**
1. From your Home Screen, select the project for which you want to create an export.
2. You are now on the Project Dashboard. Tap into any floor level of your project.
3. Tap the “Export” icon in the upper right corner.
4. Tap the [name of the export](https://help.magicplan.app/export-formats) to select and create your file.
     1. Tap the “Settings” button on the right side to configure and customize your export.
5. When your export is complete, a preview of the file will automatically open. When the preview is closed, you’ll be taken back to the floor level where you originally accessed the export menu.
6. If you return to your Project Dashboard and scroll down to the “Files” section, you will see your exports listed.
<iframe width="560" height="315" src="https://www.youtube.com/embed/XqeUQNzvTrE?si=uIyrzCZ_20vcTRDX" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
ℹ️ **Note:** Generating your export may take some time depending on how much information you are including. Do not exit the app while your export is generating.
### **How to Generate Export Files in the magicplan Cloud**
1. Log in to the magicplan Cloud and open the project you want to export.
2. Click into any floor level of the project.
3. Click the “Send” button in the upper right corner.
4. Click “Export Floor Plans”.
5. Click “Export” to create a new file or, if you want to update an existing export, click “Update.”
6. Click the blue link to open & download your file.
7. If you return to your Project Dashboard and scroll down to the “Files” section, you will see your exports listed.
<iframe width="560" height="315" src="https://www.youtube.com/embed/PWJNPI9-IXc?si=KBT1PIAGbdJ6kJ8g" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
### **How to view your exported files in the app and Cloud**
1. All exports can be found in the dedicated Files section in the app by accessing your Project Dashboard. You can save your files locally to your device by clicking directly on the newly generated file and using the options provided by your device.
2. You can [access your files via the magicplan Cloud](https://6852598.hs-sites.com/knowledge/download-your-exported-files-from-the-magicplan-cloud) on your computer, which will act as a repository for all the different files you generate for your plans.
ℹ️ **Note:** You must regenerate the PDF each time you make changes to your project. The app does not auto-update exported PDFs.
### Helpful Links
- [View](https://help.magicplan.app/export-formats) magicplan's different export file formats.
- [Add](https://help.magicplan.app/company-profile) your company's branding and contact information to your exports (only available for PDF, SVG, PNG and JPEG).
- [Create](https://help.magicplan.app/create-a-customized-export-button) a customized export button.
ℹ️ **Note:** Your ability to export certain PDFs may depend on your subscription plan. Find out what’s available with a [Sketch](https://help.magicplan.app/sketch-plan), [Report](https://help.magicplan.app/report-plan), [PRO plan](https://help.magicplan.app/magicplan-pro-subscriptions), or [PRO Estimator](https://help.magicplan.app/estimate-plan) subscription here.
