title: magicplan's Export Formats
description: An overview of available project file formats.
[Skip to content](https://help.magicplan.app/export-formats#main-content)
- [English](https://help.magicplan.app/export-formats)
- [Deutsch](https://help.magicplan.app/de/exportieren-von-formaten)
- [Español](https://help.magicplan.app/es/formatos-de-exportación)
- [Français](https://help.magicplan.app/fr/formats-dexportation)
Show submenu for translations
Open main navigation
Close main navigation
- - [English](https://help.magicplan.app/export-formats)
 Hello, how can we help you?
2. [Export & Share Projects](https://help.magicplan.app/export-share-projects)
3. [Export Your Projects](https://help.magicplan.app/export-share-projects#export-your-projects)
# magicplan's Export Formats
## An overview of available project file formats.
Magicplan offers several export formats to cater to different needs and compatibility requirements. These export formats allow users to share their projects with clients, colleagues, and other stakeholders.
### magicplan's Export Types and Formats
1. **Report PDF Export:** This export will generate a PDF file including sketch, photos, notes, details, and custom forms. This file format makes it a popular choice as it ensures compatibility across various devices and platforms.
2. **Sketch PDF Export:** This export will generate a PDF file of your sketch, including dimensions and details. This file type provides a quick and easy way to present just your floor plan to clients and stakeholders.
3. **Sketch Files:** These formats will display your project as an image file. It makes it a popular choice as it ensures compatibility across various platforms and software, such as AutoCAD.
     1. This export is available in the following file formats:
            1. SVG
            2. JPG - Compatible with: SketchUp
            3. PNG - Compatible with: SketchUp
            4. DXF - Compatible with: SketchUp, AutoCAD (dimensions will not be included)
1. **3D Export:** This export type comes in 3 different file formats that allow you to import your floor plans into 3D modeling software for further visualization or integration with other 3D assets.
            1. IFC - Compatible with: SketchUp, AutoCAD
1. 1. 1. OBJ - Compatible with: AutoCAD
1. 1. 1. USDZ - Compatible with: SketchUp, Blender
                     1. This export is the only 3D type that includes objects. It will contain all objects that can be seen in the 3D view in magicplan.
1. **Statistics Expor**t: This format allows users to export project information, such as surface area, perimeter, and living area, into a structured spreadsheet format
     1. This export is available in the following file formats: PDF / CSV
2. **Estimate Export:** The export type will generate a file with a cost breakdown of your estimate including quantities and material specifications.
     1. This export is available in the following file formats: PDF / XLS
ℹ️ **Note:** By default, newly created exports overwrite the previously generated file of the same type. You can update your workspace settings to retain the original file and create a new one (e.g., Sketch, Sketch 2, Sketch 3)
- In the magicplan Cloud, go to Settings \> Export \> Export File Versioning and check the box to create new versions instead of overwriting the previous file.
### Helpful Links:
- [Learn](https://help.magicplan.app/export-your-projects) how to export your floor plans
- [Customize](https://help.magicplan.app/customize-your-exports) your exports (layout, scale, include/exclude dimensions, etc.)
- [Add](https://help.magicplan.app/company-profile) your company's branding and contact information to your exports (only available for PDF, SVG, PNG, and JPEG)
