title: LiDAR & Auto-Scan FAQ
description: Auto-Scan is a LiDAR-based function that allows you to scan a room and all objects within it. This feature is in beta mode and has some limitations.
[Skip to content](https://help.magicplan.app/autoscan-faq#main-content)
- [English](https://help.magicplan.app/autoscan-faq)
- [Deutsch](https://help.magicplan.app/de/autoscan-faq)
- [Français](https://help.magicplan.app/fr/autoscan-faq)
Show submenu for translations
Open main navigation
Close main navigation
- - [English](https://help.magicplan.app/autoscan-faq)
 Hello, how can we help you?
2. [FAQs](https://help.magicplan.app/faqs)
3. [App FAQs](https://help.magicplan.app/faqs#app-faqs)
# LiDAR & Auto-Scan FAQ
## Read on to learn tips and troubleshooting recommendations for our Auto-Scan feature.
#### **I don’t see Auto-Scan as an option when I add a room to my project. Why is that?**
The Auto-Scan feature is available on devices with LiDAR sensors that can utilize Apple's RoomPlanner technology, which at this time is limited to iPhone 12 or newer Pro/Pro Max or iPad Pro devices. These devices must have iOS 17 or later. If your device does not meet these requirements, then Auto-Scan will not be available in your app.
#### **One of my scanned rooms is missing from the 2D plan. How do I fix this?**
If rooms are missing from the 2D sketch once you complete the Auto-Scan, this means that the room walls did not properly close during the scan; you will see these walls indicated in orange while doing the scan. Properly scanned walls will appear as green when you’re ready to complete a room, as in the first image below. An unsuccessful scan will generate an alert message with orange walls, as in the second photo. Here are tips we recommend to mitigate the issue:
- If possible, close room doors to make sure the scan is not capturing adjoining rooms.
- Use [Manual Scan](https://help.magicplan.app/scan-a-room-in-seconds-using-lidar) for open floor plans.
- Be sure to scan only one room at a time, tapping the red record button to begin, completing the scan of your room, then tapping the record button again to pause scanning and confirm the scan. Scanning multiple rooms in a single scanning session can result in lost progress if any part of the floor was not scanned correctly.
- Add [filler rooms](https://help.magicplan.app/fill-rooms) for rooms like closets or hallways that are missing from the 2D sketch.
![A correctly scanned room will appear in green.](https://help.magicplan.app/hs-fs/hubfs/complete%20scan.jpg?width=331&height=254&name=complete%20scan.jpg)   ![IncompleteScan](https://help.magicplan.app/hs-fs/hubfs/IncompleteScan.png?width=331&height=228&name=IncompleteScan.png)
#### **My room did not scan properly (the walls are orange) - is there a way to manually close an Auto-Scanned room?**
At this time, there is no method to manually complete a room that has not been properly scanned. However, the app can recognize partially scanned walls and automatically close the room for you if there is enough data to do so. Otherwise, the room must be discarded and rescanned.
If you attempt a scan multiple times without success, we recommend manually scanning that room. If you're mapping out an open floor plan, we'd suggest starting with the [Manual Scan](https://help.magicplan.app/scan-a-room-in-seconds-using-lidar) instead.
**ℹ️ Note:** Some people have found success scanning the ceiling, where the walls and ceiling meet, in open or unusually shaped spaces. While this isn’t a technical recommendation, it is something that you can try.
#### **My scanned room includes a staircase, and the Auto-Scan feature isn’t capturing it. How do I fix it?**
Staircases need to be added to your floor plan once the scan is complete. We recommend manually scanning rooms that include staircases. Once your measurements are in place, you can [add a staircase object](https://help.magicplan.app/add-structural-objects) and edit the measurements for that object to fit your floor plan.
#### **Why isn’t Auto-Scan capturing my vaulted/sloped ceiling?**
At this time it is not possible to add a sloped or vaulted ceiling in magicplan. You can refer to [this article](https://help.magicplan.app/how-can-i-add-sloped-ceilings-and-roofs) to find tips for annotating your plan with images to accurately capture this detail.
#### **My Auto-Scan added a cabinet instead of a shelf. Why did that happen?**
Objects are pulled from the Magicplan library based on what the technology interprets as the best match. If an object is incorrectly interpreted by the Auto-Scan (for example, your couch has been scanned as a table), you can delete it and add the correct one instead, resizing to best represent the real-life version.
### Why can't I scan my balcony with Auto-Scan?
Auto-Scan relies on LiDAR sensors to generate your room. The LiDAR sensor reads light bouncing off of solid surfaces, and most balcony railings or barriers are not robust enough to be visible to the sensor. This is also true for rooms with wall-to-wall windows, rooms with mirrored walls (such as gyms or dance studios), and walls without drywall that have been stripped to the studs or support structures. In these cases, we recommend using [Manual Scan in Corner Mode](https://help.magicplan.app/scan-a-room-in-seconds-using-lidar#:~:text=indicator%20will%20appear.-,(Corner%20Mode),-Capture%20the%20room%27s) instead.
#### **I'm experiencing abnormalities with drifting layouts while scanning. Why is this happening?**
Scanning requires a great deal of available memory, so it could be a matter of clearing up storage on your device in order to ensure the best app performance.
It is best to have a minimum of 10% storage available or  10GB minimum if you have a phone with small capacity (eg iPhone with 64GB total).
#### **The app is recording a video while I scan. Can I turn this feature off?**
Absolutely! Once you have finished your Auto-Scan session and tapped "Done" in the upper left corner, you will see the "Configure Floor Plan" box. Find the "Session Replay" option and toggle the feature to the off position. The feature will remain off unless or until you turn it back on.
