title: The magicplan Object Library
description: A list of magicplan's different object categories in the app.
[Skip to content](https://help.magicplan.app/the-magicplan-object-library#main-content)
- [English](https://help.magicplan.app/the-magicplan-object-library)
- [Deutsch](https://help.magicplan.app/de/die-magicplan-objekt-bibliothek)
Show submenu for translations
Open main navigation
Close main navigation
- - [English](https://help.magicplan.app/the-magicplan-object-library)
 Hello, how can we help you?
3. [Add Objects & Custom Objects](https://help.magicplan.app/create-a-project#add-objects-custom-objects)
# The magicplan Object Library
## A list of magicplan's different object categories in the app.
magicplan's object library is designed to make it easy for you to find the perfect objects for your floor plan. With a wide range of helpful categories, you can quickly locate items that are relevant to your specific needs. Simply browse through the library of objects and explore categories such as appliances, furniture, electrical, and more.
**ℹ️ Note:**
- If you do not see certain categories in your app they may be "hidden". Please follow [these instructions](https://help.magicplan.app/the-magicplan-object-menu) to adjust which object categories are "visible" and "hidden".
- If you need objects for Crime Scene Investigation please contact our support team (support@magicplan.app).
| **Object Category** | **Examples of Objects** |
| **Annotations** ([Report](https://help.magicplan.app/report-plan) & [PRO](https://help.magicplan.app/magicplan-pro-subscriptions) only) You can use these objects to indicate annotations on your 2D floor plan. | - Text Box - Shapes & Lines - 360 Panorama: This allows you to [create a virtual](https://help.magicplan.app/create-a-virtual-tour) floor plan tour. |
| **Doors** | - Hinged & Double Hinged Doors  - Pocket Door & Double Pocket Door - Folding & Double Folding Door  - Garage Door |
| **Windows** | - French Window  - Casement Window  - Hung & Awning Window  - Skylight |
| **Structural** These objects represent different parts of your floor plan's interior structure. | - [Partition Wall](https://help.magicplan.app/partial-wall-vs.-partition-wall) - [Staircases](https://help.magicplan.app/add-structural-objects) - Kitchen Counter & Island - Column & Pillar  - Fireplace  |
| **Plumbing** This category contains major bathroom and kitchen plumbing objects. | - Copper & PVC pipe  - Electrical, Oil, & Gas Furnace  - Oil, Electrical, Gas Water Heater - Sinks, toilet, & shower  |
| **Appliances** This category contains major kitchen and washer/dryer appliances. | - Electric & Gas Stove  - Refrigerator & Freezer - Washer & Dryer / Stacked Washer & Dryer - TV |
| **Kitchen Cabinets** | - Fixed & Resizable Base Cabinets - Left, Right, & Carousel Corner Base  - Single & Double Wall Cabinet  - Right & Left Corner Wall Cabinet  |
| **Furniture** | - Left & Right Arm Chair & Sofa - Couch set 4 pieces  - King, Queen, Full Bed  - Dining Table, Coffee Table  |
| **Electrical** This category contains major electrical items. | - Fixed & Mounted Lights - Wiring / Outlets / Switches / Electrical Panels - Ceiling Fans |
| **Outdoors** This category contains various outdoor elements, from pools to landscaping, that can be used in a [Land Survey](https://help.magicplan.app/create-a-land-survey). | - Fencing  - Swimming Pool & Deck  - Plants   |
| **HVAC** | - Rectangular & Circular Duct - Heater, Furnace, Radiator - Portable & Wall-Mounted Air Conditioner  |
| **Garage** | - Garage Door - Electric Charger  - Breaker Panel - Car, Truck, & Bus - Work Station |
| **Fire & Safety** ([Report](https://help.magicplan.app/report-plan) & [PRO](https://help.magicplan.app/magicplan-pro-subscriptions) only) This category contains emergency and safety signs. | - Exit & Evacuation Path - Eyewash Station & Safety Shower - Water, CO2, & Dry Powder Extinguisher - "No" Signs & "Warning" Signs  |
| **Restoration** ([Report](https://help.magicplan.app/report-plan) & [PRO](https://help.magicplan.app/magicplan-pro-subscriptions) only) | - Air Mover / Air Scrubber / Floor & Wall Drying System - Dehumidifier / Humidity Temp. Measurer  |
| **Durable Medical Equipment** ([Report](https://help.magicplan.app/report-plan) & [PRO](https://help.magicplan.app/estimate-plan) only) | - Wheelchair  - Commode Chair  - Tub Bench |
| **School** | - Teacher, Student, Group Table - Blackboard, Whiteboard, & Interactive Whiteboard - Lockers |
| **Office** | - Single and Corner Desk - 2 Person Workspace  - Conference Table  - 1, 2, 3 Door and File Cabinets |
| **Alarm & Security** ([Report](https://help.magicplan.app/report-plan) & [PRO](https://help.magicplan.app/magicplan-pro-subscriptions) only) | - Surveillance Camera & Security System - Smoke, CO2, & Heat Detector  - Keypad |
| **Retail Store** | - Checkout Counter & Cash Register - Shelving Units & Clothing Rack  - Escalator & Elevator - Fitting Room |
| **Flat Roof** | - Dry Cooler  - Scupper & Roof Drain  - Roof Hatch  - Pitch Pocket |
| **COVID-19 Response** | - 6ft & 1.5m Measures - "No" Entry, Seating, Walking Signs - Mask Required Sings - Temperature Check |
ℹ️ **Note:** Not all 2D objects will have a 3D rendering available. If you use an object and do not see it in your 3D view, we have not included a 3D rendering for that object.
