How to Export Your Floor Plan's Statistics
Generate a detailed report of your floor plan's measurements.
Exporting Statistics in magicplan allows you to extract and analyze data from your projects as a CSV or PDF file. This data includes information about rooms, objects, surfaces, measurements, and more. By exporting this data, you can gain insights into your project's progress, costs, and other important metrics.
How to access Export Statistics
- From the home screen of your app, tap the floor plan you want to export.
- You are now on the Project Dashboard. Find and tap the "Files and Sharing" option in the lefthand menu.
- Scroll down and tap on the " Statistics " section to generate a PDF or CSV of your statistic file.
- To customize the export and select the file type you want to generate (PDF or CSV) tap the settings icon button to the right of the Statistics export.
