How to Create Curved Walls
Learn how to create curved walls in magicplan.
The present version of magicplan does not have the option to draw or scan curved walls. However, you can use the "Add Corner" feature to create a curved wall by approximating a polyline.
How to create a curved wall:
  1. Draw or scan the wall in your room as a straight wall.
  2. Use the inverted triangle indicators to tap on the length of the wall and designate where you want to add a corner.
  3. Tap on “Add Corner” from the menu, and you will then see a corner appear on your wall.
  4. Tap and drag a corner out to begin your curve.
  5. Repeat adding and dragging corners along the wall till you have a curved wall.
