title: "Restoration: Equipment Placement on Your Floor Plan"
description: Learn how to use magicplan's Restoration objects to place equipment accurately throughout your project.
[Skip to content](https://help.magicplan.app/restoration-equipment-placement#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Hello, how can we help you?
2. [Industry Resources](https://help.magicplan.app/industry-resources)
3. [Restoration](https://help.magicplan.app/industry-resources#restoration)
# Restoration: Equipment Placement on Your Floor Plan
## Learn how to use magicplan's Restoration objects to place equipment accurately throughout your project.
Accurately documenting the placement of equipment on-site is essential for effective project management, insurance claims, and clear communication with clients. The magicplan app provides a range of Restoration Objects that enable you to visually represent various types of equipment on your floor plans. Here’s a guide on how to add these objects and the different scenarios in which they can be applied.
**ℹ️ Note:** If you are unable to find an object you need in magicplan, you can create your own [Custom Objects](https://help.magicplan.app/custom-objects) to utilize in the app.
### Benefits of Using Restoration Objects
Using magicplan’s Restoration Objects provides several benefits for restoration professionals:
- **Accurate Documentation**
    - Ensures precise placement and detailed records of equipment used on-site.
    - Facilitates clear communication with clients, insurance adjusters, and team members.
- **Efficient Project Management**:
    - Assists in keeping track of equipment deployment and retrieval.
    - Helps plan and optimize equipment usage across different areas of the property.
- **Enhanced Reporting**:
    - Provides comprehensive visual documentation for insurance claims and progress reports.
    - Improves transparency and accountability in restoration projects.
### magicplan's Restoration Objects
**Water Damage Restoration**:
- **Dehumidifiers**: Place dehumidifiers in rooms affected by water damage to document their usage and optimize their placement for efficient drying.
- **Air Movers**: Add air movers to floor plans to show their strategic placement for maximum airflow and drying efficiency.
- **Wall Humid Zone:** After a flood, indicate which sections of walls are wet to focus on wall cavity drying.
- **Wall Cavity Dryer:** Deploy wall cavity dryers in a bathroom to address moisture behind tiles after a leak.
- **E-TES:** Deploy E-TES units in a water-damaged attic to expedite drying of insulation and structural components.
**Fire Damage Restoration**:
- **Air Scrubbers**: Position air scrubbers to indicate areas where smoke and odor removal is being addressed.
- **Ozone Generators**: Document the use of ozone generators in rooms to show efforts in deodorizing and sanitizing affected areas.
**Mold Remediation**:
- **Moisture Meters**: Use moisture meters to monitor and document humidity levels in various rooms, ensuring proper drying and mold prevention.
- **Humid Zone:** In water-damaged basements, mark areas where humidity levels are consistently high to prioritize drying
- **Hydroxyl Machine:** Place hydroxyl machines in a living area affected by mold to purify the air.
<iframe width="560" height="315" src="https://www.youtube.com/embed/n-4bt7qX2Bo?si=LPl6nvZRtg9f0oPA" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen style="position: absolute; top: 0px; left: 0px; width: 100%; height: 100%; border: none;"></iframe>
Learn more about magicplan's objects [here.](https://help.magicplan.app/the-magicplan-object-library)
