Release 2024.2.0
With this update we are enhancing Custom Form exports and expanding the object catalog.
Version number: 2024.2.0, Release date: February 2nd, 2024
UX Enhancements
We are on a mission to build great, easy-to-use tools for professionals! To this end, we try to push UX enhancements every month. If you have feedback, please share your ideas - We’re always happy to connect with members of our community!
  • Custom Forms: Use the new export configuration to start every Custom Form on a new page in the PDF. This setting allows you to easily separate Custom Forms from your PDF.
IMG_BCC554A84FE6-1
  • New objects: We have updated the object catalog with new 2D and 3D objects for garages and sectional sofa designs
GaraageSofaObjects
API Update · Project Files
We introduced a new API endpoint that list all files associated to a project: The updated documentation for the APIs can be found here.
Bug Fixes
  • Fixed: Custom Forms · Instructions are only visible when the device language is set to English
  • Fixed: Photo Download · The photo ZIP download fails if there is a blank image in the selection
Webinars
