With this update we are introducing a new integration with Xactimate® and a dedicated API for Custom Forms and Attributes
Version number: 2023.10.0, Release date: August 28th, 2023
This release introduces a new integration with Xactimate® and a dedicated API for Custom Forms and Attributes.
Send your magicplan sketches to Xactimate® in seconds
With this integration, restorers and claims professionals can export floor plan sketches directly to Xactimate®. Learn more here.
Custom Forms & Attributes API
Use this new endpoint to easily access Custom Form & Attribute data via API. Read the documentation on Swagger
Bug Fixes
- Fixed: Photos and Custom Form data disappeared in some cases
- Fixed: Some Bosch laser meters are not connecting to magicplan
- Fixed: Some objects are not displayed correctly in 3D
