How to Delete Walls
You can delete individual walls from any room using the magicplan app. This helps you refine floor plans and make changes on the go.
It’s easy to remove walls with just a few taps. Whether you're updating an existing layout or fixing a mistake, this quick guide walks you through the process.
Steps to Delete a Wall
  1. Launch the magicplan app and select the project you want to edit.
  2. Navigate to the floor that contains the wall you want to remove.
  3. Select the room where the wall is located.
  4. Tap the wall you'd like to delete. It will turn blue when selected.
  5. On the left side of the screen, tap the “Delete” button to remove the selected wall.
💡 Tip: If you delete a wall by mistake, you can quickly undo the change by tapping the “Undo” arrow at the top of the screen.
