Help Center
Go to www.magicplan.app
Contact us
How can I measure and sketch?
What's new with magicplan
Feature Highlights
Integrations
Cloud Mini-Series
Latest Updates iOS / Android
First steps
Save your projects
On the way to your first project
What is magicplan?
Create a room
Adjust your floor plan
Add objects to your floor plan
Create custom objects
Connect a laser
Create a land survey
Assemble your rooms to a floor plan
Create 360 walkthroughs
Add information and pictures to your floor plan
Customize your reports
Export your projects
Share your projects
FAQs
Account-related questions
App-related questions
Cloud-related questions
Subscription-related questions
Other questions
Pricing and Billing
Pricing
Billing
Privacy & Terms
Integrations and API
Integrations
Update Log
Android Update History
Important Application Updates
iOS Update History
Back to home
Help Center
Feature Highlights
Integrations
Cloud Mini-Series
First steps
Save your projects
What is magicplan?
Create a room
Connect a laser
Share your projects
FAQs
Other questions
Pricing and Billing
Pricing
Billing
Privacy & Terms
Integrations
Update Log
iOS Update History
Just getting started with magicplan? This section will cover all the basics around measuring and sketching your first floor plan.
Create a room
Scan a Room With the Camera of Your Mobile Device (iOS)
Create a Room With the Square Room Feature
Create a Room With the Define Corners Feature
Import and Digitalize an Existing Floor Plan
Fill Rooms
Duplicate Rooms
Scan a Room With the Camera of Your Mobile Device (Android)
See more
Undo
Adjust the Ceiling Height of Single Rooms
Split Rooms
Add Curved Walls
Delete Rooms and Objects
Change Exterior and Interior Wall Thickness
Merge Rooms
Add Partial Walls
Add Corners
Freeze Walls
Living Area Calculation
Setting the Ceiling Height for a Specific Floor
Change Room Color
Copy a Floor to a Different Project
Partial Wall vs. Partition Wall
Change Units
Move a Room to a Different Floor
Change Dimensions of Your Floor Plan
See more
Add Structural Objects
Add Furniture Objects
Measure the Distance Between Objects and Walls / Other Objects
Elevation of Windows, Doors and Other Furniture Objects Attached or Next to a Wall
Add Carpeting and Tiling to your Floor Plan
Edit Furniture Objects
Duplicate Furniture Objects
Adding Wall Objects
The magicplan Object Menu
See more
Create Custom 2D Objects Based on Existing Objects or by Using the magicplan Editor
Create Your own 2D Objects by Importing SVG Files
Integrate Custom 3D Objects in magicplan
Connect a laser
Laser Distance Meters
Create a Land Survey
Assemble your Rooms to a Floor Plan
