Floor plan creation
Step by step: how to create a floor plan.
Oliver Vogel avatar Bernd Wolfram avatar
26 articles in this collection
Written by Oliver Vogel and Bernd Wolfram
Adjust your floor plan
Change dimensions
Adjust the dimensions of your floor plan the way you need them to.
Oliver Vogel avatar
Updated over a week ago
Add corners
Adjust the shape of your room by adding corners.
Oliver Vogel avatar
Add partial walls
Add partial walls with ease.
Oliver Vogel avatar
Split room
Divide a room into two separate rooms.
Oliver Vogel avatar
Merge Rooms
Unite two rooms and merge them together into one room.
Oliver Vogel avatar
Specify the ceiling height of floors
Make your floor plan more precise and add important information by adjust the ceiling height.
Oliver Vogel avatar
Assemble Rooms
You have captured all rooms? Assemble them like a puzzle and create complete floor plan.
Oliver Vogel avatar
Change exterior and interior wall thickness
Change the exterior and interior wall thickness to make your plan more precise.
Oliver Vogel avatar
Change units
You can display floor plans in the metric or the imperial system - whatever you prefer.
Oliver Vogel avatar
Freeze walls
Freezing walls helps you to make sure you don't change the dimensions of walls by mistake.
Oliver Vogel avatar
Change room colour
Bring colour to your plan to make different room types obvious.
Oliver Vogel avatar
Move a room to a different floor
You have already created a room but then decided it should be on another floor - no problem.
Oliver Vogel avatar
Living area calculation
Calculate your actual living area.
Oliver Vogel avatar
